CaptainGizmo
RVF Expert
- Nov 3, 2019
- Newell
- 2020P
- 2017 Ford F-150 Raptor w/AF1 Braking
Ok, enough...this is just not right, and I’m guessing plenty more have the same experience. But my goal is to get it fixed!
So, after 20k miles and a bit of night driving, I am 100% convinced the headlights on our 2019 Dutch Star (Spartan) are not wired correctly.
Before we go any further, I’ve adjusted and replaced my bulbs with top of the line LEDs...for $200.
When I hit the high beams, my lights virtually disappear...totally unusable...No light remains in front of the coach at all. Both myself, and Newmar, have been unable to adjust the lights downward any further, thanks to the crappy mounting system they use, which makes the housing hit the body. The beams are aimed too high, and I get flashed occasionally. I feel as if the lights are on High-beam when supposed to be on low, but when flipped to High...I’m not sure what’s happening, but it ain’t good!
Furthermore, and even more convincing, is that the ”FLASH TO PASS” momentary toggle on the turn-stalk DOES NOT WORK when the beams are on LOW. It DOES, however, work when on HIGH. Huh? Yeah, when the beams are on HIGH, and you toggle the lever, your beams flicker to LOW. NO NO NO...that’s NOT the way that system is supposed to work.
I think I’ll remove a bulb and keep it connected and, with my good sunglasses, see what the actual bulb is doing.
Before addressing this with Spartan, because that’s EXACTLY who Newmar blames for chassis wiring, I wanted to hear from you all to see how many have the same problem. And, I KNOW there are...because we tested another 2019 at Newmar Service last year and it did the same thing.
This is NOT a discussion on “what type of bulb to use”, “replacing your headlights”, or “this is why I don’t drive at night”. There are other thread for that, so please don’t post those suggestions here.
