jagpot
RVF VIP
- Nov 17, 2020
- California
- King Aire
- Spartan
- Cummins
- Jeep Wr Sahara
Is a DEF tower the same as a DEF head. Hope not. because I have the issues you had mentioned and after they take care of some nox valve they are going to delve into the DEF issue.TJ, several years ago I had a twin diesel inboard boat. It had different diesels than what your Cummins is, but I had an issue with one engine not shutting down. It turned out to be a bad switch that killed the fuel feed to that motor. On those older diesels you not only turned the key off but held a kill switch in to stop the fuel. So I guess what I'm saying is even modern diesels will stop once the fuel is shut off.
I can recall having a "check engine" light come on several times with my 2017 4369. I had it looked at by two different FL/Cummins service centers and one said it was some type of sensor for the DEF being too hot and the other said the code was simply a ghost code and no big deal. When I landed back in Florida with it on again I went to North Trail and they plugged up the computer and immediately said I needed a new DEF tower. Problem solved by an RV dealer......go figure.
