Jim
- Dec 18, 2019
- North Carolina
- London Aire 4551
- Freightliner
- Cummins / I6 Diesel Pusher 600HP / 1,950 ft-lbs
- 2016 Jeep Rubicon
In an email sent today, Starlink is going to enforce data caps starting December 2022, email follows.
To ensure our customer base is not negatively impacted by a small number of users consuming unusually high amounts of data, the Starlink team is implementing a Fair Use policy in December 2022.
Under the Fair Use policy, all Business customers will receive unlimited data, and will start each month with Priority Access, which means their data usage will be prioritized during times of network congestion.
Customers who exceed 1 TB of data use on a monthly basis (currently < 10% of users) will automatically be switched to Basic Access for the remainder of the billing cycle, and will be bitrate limited to 1 Mbps download and 1 Mbps upload.
Data used between 11pm - 7am will not count towards your Priority Access.
In the last six months, you have used over 1TB of data during at least one month, which means you may be bitrate limited if your usage patterns stay the same.
You will have the option to opt-in to automatic upgrades back to Priority Access should you exceed 1 TB of data per month.
Starting today, you can now monitor your data usage on your account page. Read more in Starlink’s Fair Use policy and in the Terms of Service.
Thank you for being an early customer and for your continued support of Starlink!
Starlink Team
NOTE: The Terms of Service also include updates on using the HP Flat Starlink designed for in-motion use. By continuing your use of Starlink, you agree to be subject to the Fair Use policy and the updated Privacy Policy and Terms of Service. If you do not agree to these changes, you can cancel your Starlink Services at any time via the Customer Support Portal.
