Rd1
- Feb 16, 2022
- ̶N̶e̶w̶m̶a̶r̶
- ̶L̶A̶D̶P̶
- ̶F̶L̶
From your description, it sounds like, the oasis is upto temp. If the red hoses are hot, the oasis fluid is hot enough, hence the elec elements have no need to turn on and likewise, the burner kicks in for a short burst, then the fluid is hot enough, so it goes off. That all sounds normal.I believe the Oasis temp is at temp. I say this because when I grab hold of the two red hoses that go into and out of the main unit, they are hot.
The burner functions, at least for a little while. I've heard it once in a while, but it only runs for a few minutes and then shuts off.
For your oasis heat you may want to leave the oasis SL config to secondary heat source.
Also, have you tried to turn the summer loop on? If not, turn it on, see if that helps with hot water and oasis heat.
