Jim
- Dec 18, 2019
- North Carolina
- Essex 4543
- Spartan
- Cummins / I6 Diesel Pusher 605HP
- 2016 Jeep Rubicon
Sounds like you’re adaptingTrish told me the high is going to be 72. What glorious words. I think I'll trim my banana tree today.
The info provided is limited, so some of the questions may seem irrelevant.I’ve been unable to determine why Silverleaf says “No AC Input”. Checked breakers, fuses and even changed from the Oasis Node Board to the backup board they leave attached to the Oasis (on Silverleaf models)
Waiting on a return call from the Oasis folks.
I believe the Oasis temp is at temp. I say this because when I grab hold of the two red hoses that go into and out of the main unit, they are hot.The info provided is limited, so some of the questions may seem irrelevant.
The 'No AC Input' is a normal message. It indicates, either there is no 110v available, or when there is 110v, the oasis fluid is at temp, hence the AC elements are turned off. When oasis fluid temp drops below set min, the AC elements will turn on.
I see the burner appears to be off? Have you tried the burner to see if it functions?
Simple question, is there hot water? also, is the SL configured for primary heat, secondary heat or both?
You may also want to verify the SL settings to make sure all is setup correctly
Have you tried installing a maintenance kit? The five year kit has everything but there are 1 and 3 years kits avail (you probably already know this) but the point is you may have a bad flame sensor and the good news is that it’s undoubtedly maintenance issue and the work is easy and, dare I say, fun. Ok at least not unpleasant. So thats my rec - lots of how to videos ( guess thats called DIY these days) on you tube etc.I believe the Oasis temp is at temp. I say this because when I grab hold of the two red hoses that go into and out of the main unit, they are hot.
The burner functions, at least for a little while. I've heard it once in a while, but it only runs for a few minutes and then shuts off.
No hot water. Silver leaf was configured for both, but over the last couple of days, I've tried all configurations.
The only thing that has changed recently, is I no longer get a Zone Fault message at the top of the SL. It now says "Zones OK", "Heater OK", and "No AC Input".
Called a couple of mobile mechanics, but nobody wants to work on the Oasis for some reason.
From your description, it sounds like, the oasis is upto temp. If the red hoses are hot, the oasis fluid is hot enough, hence the elec elements have no need to turn on and likewise, the burner kicks in for a short burst, then the fluid is hot enough, so it goes off. That all sounds normal.I believe the Oasis temp is at temp. I say this because when I grab hold of the two red hoses that go into and out of the main unit, they are hot.
I hadn’t thought of that. When the flame sensor is bad it only runs for a couple seconds.From your description, it sounds like, the oasis is upto temp. If the red hoses are hot, the oasis fluid is hot enough, hence the elec elements have no need to turn on and likewise, the burner kicks in for a short burst, then the fluid is hot enough, so it goes off. That all sounds normal.
@Jim watch this and you’ll be all set to do your own Oasis work:
This is where I’ve always bought service kits:
High-Quality Oasis Annual Service Kits | Hydronic Heating Warehouse
Looking for reliable and high-quality annual service kits for your Oasis heating system? Look no further than Hydronic Heating Warehouse. We offer a wide selection of service kits that include all the necessary replacement parts and components to keep your system running efficiently & reliably...hydronicheatingwarehouse.com
They can be intimidating at first but once you get into them its not bad at all. I was surprised by that too. One less thing you have to pay to have done.Excellent video, thank you so much Rich! I had no idea servicing these things was so simple.
Thanks guy's! I can't do much of anything until I get the coach back from Freightliner. NIRVC was unable to determine what was causing the previously mentioned SPN 3363 FMI 16 code, and suggested it may be something that won't happen again. But that wasn't the case, and it reared its ugly head as we entered Florida. So now Freightliner can take a stab at it. Hopefully I'll have it back to get to Key West on time.
What was the reason you took it there? Are they an OASIS branded FL location (meaning RV service center)? I hope it's not a misdiagnosis and you called 800-FTL-HELP for their guidance.My rig's been sitting at Ocala Freightliner for the last two days.
