Our 2023-2024 Southern Migration Trip
I believe the Oasis temp is at temp. I say this because when I grab hold of the two red hoses that go into and out of the main unit, they are hot.
The burner functions, at least for a little while. I've heard it once in a while, but it only runs for a few minutes and then shuts off.
From your description, it sounds like, the oasis is upto temp. If the red hoses are hot, the oasis fluid is hot enough, hence the elec elements have no need to turn on and likewise, the burner kicks in for a short burst, then the fluid is hot enough, so it goes off. That all sounds normal.
For your oasis heat you may want to leave the oasis SL config to secondary heat source.
Also, have you tried to turn the summer loop on? If not, turn it on, see if that helps with hot water and oasis heat.
I'd also attempt a complete reset, just for try. reset the oasis and the SL
Amazon product ASIN B01N75RKTE
ehhh, 5 year service kit out of stock, 1 year service kit is available
Amazon product ASIN B015GBQGH8
You don't need a mechanic or look for a RV mobile tech. You can do this yourself with some YouTube research first. It's not a complicated system.
On the side wall of the OASIS system is your distribution panel with LED lights. On top of that is a switch to override the system, i.e. forcibly run all pumps. Have you tried turning that ON and see what happens?
I hadn’t thought of that. When the flame sensor is bad it only runs for a couple seconds.
@Jim watch this and you’ll be all set to do your own Oasis work:
This is where I’ve always bought service kits:
If there isn’t an error on the Oasis, and the Oasis isn’t running the heat in the coach, then it seems like there is a problem in the thermostat/SL that is preventing a signal from being sent to the Oasis to run the coach heat.
I don’t know the fancy SL type controls as our coach has the older thermostat on the wall setup.
Thanks guy's! I can't do much of anything until I get the coach back from Freightliner. NIRVC was unable to determine what was causing the previously mentioned SPN 3363 FMI 16 code, and suggested it may be something that won't happen again. But that wasn't the case, and it reared its ugly head as we entered Florida. So now Freightliner can take a stab at it. Hopefully I'll have it back to get to Key West on time.
Excellent video, thank you so much Rich! I had no idea servicing these things was so simple.
They can be intimidating at first but once you get into them its not bad at all. I was surprised by that too. One less thing you have to pay to have done.
My rig's been sitting at Ocala Freightliner for the last two days. Wow, what an experience. The girl who answers the phone and also works the front desk, has apparently been to Freightliner school and excels in doing everything possible to be unhelpful.
My coach needed a DEF heating unit, about $1,000 at a dozen other places, but Ocala Freightliner is charging me $1,920.44. Then to install this friggen piece of gold, I have to pay another $1,125.00. Not sure, but I don't think there are more than a handful of bolts to remove/replace, a few hoses to clamp, and then clear the code.
So total out the door cost of doing business with Ocala Freightliner will be $4,147.95. I understand everyone has to make a profit, but this is crap.
Jim I can't believe the bad luck your having, and wish there was something I could help you with. A friend and also my mechanic said he could remove all the def junk on my coach for 25 hundred,and it would run much better and last longer. I said I didn't want to take a chance of getting in trouble. Your colorful explanation of the freightliner employees was priceless!
I hate to hear about your troubles. All your hard work to have a nice place we can all enjoy, you both deserve your time to relax. Hang in there, better days ahead.
What was the reason you took it there? Are they an OASIS branded FL location (meaning RV service center)? I hope it's not a misdiagnosis and you called 800-FTL-HELP for their guidance.
For that price difference I would be considering driving it to a different location to save the extra $1.5k-$2.0k
Sorry you are going through this.
Dave
