Dyndns would work. It needs either a host name or IP.Curious, as this was on my list, trying to get VPN to home either to my sonicwall (not ideal) or was thinking an extra max BR1 I have.
Not the only thing that might be a problem is I don't have a static IP at home. I have dyndns setup, but not static (though my lease will often last for months).
Does fusion hub require a static IP for VPN tunnel from peplink router.
Awesome. Will spin up a fusion hub in VMWare this weekend and start playing. Thanks.Dyndns would work. It needs either a host name or IP.
I have a T-Mobile 5G sim card and I use it in my Peplink 5G CAT 20 router. The T-Mobile works just fine. I end up using it more than the AT&T sim card that I also have. The AT&T runs at 4G most of the time.After reading this thread I took a look at the Pepwave MAX BR1 Pro 5G Router for use with a T-Mobile 5G SIM and Verizon 4G SIM but before I can order one from the 5GStore I have to click that I know that and I quote "I understand that T-mobile doesn't support consumer 5G plans for this device". Does anyone have any experience with T-Mobile 5G and the Pepwave 5G Router?
You have a dedicated IP at home? That seemed to be happening to me in RV when I had all my WANs set to fastest response (same priority, using then ask but no fussing hub). I think it was getting confused somehow and had same issue you describe.I think I'll be discontinuing use of FusionHub. I've noticed it is throwing my iPhone for a loop, not receiving messages, phone calls, push notifications, etc. I reboot my phone and the flood comes in (cellular only). Happened to me twice now that I'm not sure what's going on but the iPhone is not liking this Internet situatio
Hmmm. I know the issue you describe. The last two days I was at the park, I was cashing my wife's phone every hour or so to make sure it was no longer a problem.I am connecting to my server in a data center - dedicated IP. I don't know if it matters that this is through a firewall but FusionHub requires ports to be opened which are per docs.
