2022 Newmar London Aire 4551 - RedBaron Build
When we pull wire thru conduit, we do all at one time. Near impossible to do one at a time after the first. The wire bundle is assembled staggered start so they come to a "point" which is where the nylon pull cord is wrapped. The pull cord wraps around in a way that when the rope is pulled, the rope strangles the wire. Then, electrical tape secures the cord to the spine making a pointy nose, and the rest of wires staggered wrapped to the spine. If a few corners, then use wire pull lube. Always run another pull cord with the bundle for future.
My 2002 Newmar had Blue convoluted tube that was I think 3/4" ran by Newmar. So, that would fit a couple Category cables, a Coax, a low voltage power line,
3/4" will be tight with the ends on it, but should work. I might cut the ends to make it easier.
3/4" is going to be a challenge for sure.
I just emailed Parsec as I had two connectors where the pins fell out or were left on the pepwave side. May have been me tightening them too much or a defective build on the connector, who knows. I pushed the pins back in and will see if they work well but I wanted to know what connectors to get should I have to replace them.
They use LMR200 cable
Connectors (I bought spares from Mouser.com):
  • The cellular connectors are: AMPHENOL RF,132234
  • WIFI connectors: AMPHENOL RF,132234RP
I used these cable covers to put over the area the cables go into the roof then put Sikaflex 221 in the hole with wires and then of course dicor.
I am going to solder my pins. Decided to cut the ends off to get more room.
Getting my centramatics installed at the factory.
Interesting - is there an issue with balance or is this preventative?
It's a one time balance that continuously adjust, both to speed and tire wear.
I run these on all trailers and all my prior motorhomes.
When I first was introduced to Centramatics was in 2010 on my Fleetwood Discovery. I had 2 years of driving on the tires, and they had a terrible wear pattern. I rotated the fronts to the back, and put new ones on. After 500 miles, I really didn't feel good about the quality of the ride. I happen to live close to Centramatics, and I stopped by to talk to them about it. They put a set on, and the ride was instantly better.
In addition to continuous balancing, they also act as a heat sink for the brakes, and a dust shield.
By doing it up front, I will keep the tires running the best possible for their lifetime.
Movin on up! Saaweeet rig! Best of luck
Wow. That is a nice coach. Enjoy.
Well you got me thinking about them. Im taking one more trip on the current tires. Then they will have about 58000 and 7 years since produced, 6 years on the road. Since balancing big tires often seems to be a challenge for tire shops, I might just pick up a set of Centramatics and have them available for the tire shop later in the year. Im driving right by Alvarado in June.
