B&T RVers
- Nov 4, 2020
- Vero Beach, FL
- Ventana 4037
- 40"
- 2018 Jeep Wrangler Sahara
A gfci will not trip if no power is present. Check the breaker!All my outlets in the basement don’t work. I went to reset the GFCI but it doesn’t reset. Neither the test or reset can push it.
I am guessing it needs replaced, but it looks very specific t the rig - both the color and the size.
Thanks in advance.
2021 Newmar Ventana 4037
Just a side note:SOLUTION!!!!!
I spoke with a Newmar tech. When you have an issue with your outlets & the GFCIs won’t reset there is a sequence you need to follow. This is the sequence for a 2021 Ventana 4037.
#1: reset the one in the 1/2 bath
#2: reset the one under the kitchen cabinets above the cook top
#3: reset in the basement where the central vac and other electrical boxes
#4: reset in the front passenger side basement compartment where you could put a refrigerator.
This sequence solved the problem!
