jagpot
RVF VIP
- Nov 17, 2020
- California
- King Aire
- Spartan
- Cummins
- Jeep Wr Sahara
What have you read? Very curious about this. RV is at Cummins now for several issues but also have that pesky 4 bars to LOW DEF in 1 minute issue . Sounds like a failed sensor since tank was over half full. Where can I go to study up on this?There is a solution to the Def head. The sensor is using the CAN bus to send a signal that the DEF is proper mixture, and the levels are good. This can be faked. There are many companies that create this type of device, although mainly for the 1 ton diesel truck market, it does also run on the larger OTR trucks.
If it is used along with an actual DEF and DPF in place, there is nothing illegal about it. The fix will just allow the def head to be ignored, and the system will continue to use the DEF fluid.
I have not personally done this , but I do know that this is possible.
