- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
For those with the panel above the entry stairs with the AC I - OFF - II there is a green LED (diode) next to the switch. Some think that when the green light is ON then OASIS is on and doing it's thing. This is not true and something I believed for a while as well until all of the electrical issues I had with my OASIS which afforded me the opportunity to better understand the system.
Take the scenario of those that want to have the furnace on while driving to provide heat. Some have said to just turn on AC I which will show you the green light and that will provide heat. That is NOT true. What is actually providing heat is the engine heating the hydronic fluid (anti-freeze). In order for AC I / II to work you must have 120V power either from shore power or the GEN.
So what does that green light mean?
In your OASIS "green box" are 3 relays for each electrical element and the diesel burner. A relay allows a low power signal to open a circuit for a higher power path. So in the case of this "green light" the switch up front is only sending a 12V signal to the relay(s) in the OASIS unit closing the bridge per se so that 120V current can pass through, if available. The green light is only indicating that the 12V signal is being sent to the relay to "open" and allow 120V current to pass. It does not indicate anything is running, on, available to provide heat. When OASIS is running and passing current (120V) to the electric elements you will see the other green light on the right side of the panel near the fault light, burner green light, etc.
There are a lot of misconceptions out there and I hope this helps better understand the OASIS system for some. I read a lot of the chat in the RV Facebook groups and it's concerning how many don't really know their RV systems and it took me a long time to learn as well. The education channels are simply not there to learn from and forums like this is one of the better sources of info share.
If you know of a system that is not well understood and you see discussions out there that get your attention, please consider educating others by posting content such as this to help each other better understand their coaches and systems.
